Hi,In 2009 I will be able to rent 300 acres of ground for corn and bean production in Iowa. I am now starting to look at what the best line of equipment will be. I have myself budgeted to an $8000 tractor which will be the only tractor I will have for the first few year. I don't have alot of freinds and family close and work a full time job. So I need a tractor that can go good speeds and have a low probablity of getting stuck as I don't have alot of options for pulling me out. I would have a grain truck but would have a smaller grain cart that I would use with the tractor. I would also use this tractor for disk chiseling, field cultivating, planting, anhydrous application, and possibly corn and bean cultivation if needed, I would take the duals off for planting,anhydros,corn and bean cultivation. Right now I am leaning towards Case 2470,2670,4490,4690 as being a good fit for this operation. The price is right($5000-8000),seem to be a very well built tractor, and would get the job done quickly even in damp conditions without getting stuck, this is bases mostly on old posts I have seen from you fine gentlemen. One of my concerns is the steering, how clumsy is it, would it be precise enough to drive between the rows with out running your crops over. I would run crabsteer for the disk chiseling and field cultivation and am hoping that front steer alone would be precise enough for planting and other row crop operations. Also do you have to be careful turning around in crabsteer mode, is it possible to damge your impement if turning to sharp? Thanks for your help.
