Taking a bottom off a 3 bottom plow?
30 pointer
04-17-2007 07:43:15
I have a case 6000 plow 3-16" trip spring mounted plow. I am using a ford 841 tractor with approximately 42-45 Hp. I am having promblems pulling the plow. Can I drop one of the bottoms? I would like to drop the front bottom because I have clearance issues when lifting the lift arms the front plow wants to drag on the ground once in a while? The furrow wheel is actually a tire mounted on the side of the plow. I know I can take off the plows no problem but will the plowing be correct in the field?
Glenn F.
04-17-2007 14:45:47
 Re: Taking a bottom off a 3 bottom plow? in reply to 30 pointer, 04-17-2007 07:43:15
Unless that tractor weighs about 6,000#, you may even have trouble with 2-16's.
I know you would here (Green Bay, WI).
Glenn F.
bradley martin
04-17-2007 11:13:34
Yes...bottom,and furrow are used interchangeably.
JGarner
04-17-2007 10:57:38
We took the last bottom off our 3 bottom Case BER mounted plow. All that neded to be done was move the tail wheel.
Gary in Pulaski, WI
04-17-2007 10:24:30
Actually, you would remove the last "bottom" and then switch some of the hardware onto the second (now last) bottom. You need the landslide, and perhaps the 'FOOT" THAT RIDES THE BOTTOM OF THE FURROW. I don't know if your plow has any sort of depth control, but that may need to be moved also. Some plows just don't allow for the removal of one bottom at all, because of the way the frame is constructed. We do have a 2-3 bottom fully mounted CASE plow that did allow us to remove the third bottom just as I described. Use lots of PB Blaster on the nuts of the bolts.
bradley martin
04-17-2007 09:54:56
You can NOT drop the front bottom off and expect the plow to function properly. You can remove the last furrow and still plow correctly.
30 pointer
04-17-2007 10:01:42
 Re: Taking a bottom off a 3 bottom plow? in reply to bradley martin, 04-17-2007 09:54:56
When you refer to the last furrow are you refering to the last Plow?
30 pointer
04-17-2007 10:01:34
