Vac hydraulic fluid spec
cptmobile
04-17-2007 06:16:22
What type of fluid is used in the VAC hydraulic system.
Thanks
Jeff
mj
04-17-2007 19:47:02
 Re: Vac hydraulic fluid spec in reply to cptmobile, 04-17-2007 06:16:22
Click the link:
Farmer Jack
04-17-2007 06:55:02
The older VAC's used a 10W in the belt pulley for the high pressure hydraulic lift. The newer eagle hitch units probably used the same. For a more modern fluid a Case-IH Hytran or Deere Hy-guard will probably serve your purposes just fine.
