Clutch Back Plate on Case L
triplow07
04-16-2007 19:25:11
Does the clutch back plate have the cut female spline grooves that the clutch shaft splines slide into? If so, how much slop is permissable? On my L, there is slop between these splines which causes chatter. I took off the inspection plates, engaged the clutch (engine off), and moved the belt pulley back and forth. I can see the movement in the splines.
Walt Davies
04-17-2007 09:03:21
 Re: Clutch Back Plate on Case L in reply to triplow07, 04-16-2007 19:25:11
I wouldn't think that there should be any noticeable play in the splines. Walt
triplow07
04-17-2007 17:48:33
 Re: Clutch Back Plate on Case L in reply to Walt Davies, 04-17-2007 09:03:21
Do you have any thoughts? I can see the back and forth movement between the splines.
Walt Davies
04-18-2007 08:06:05
 Re: Clutch Back Plate on Case L in reply to triplow07, 04-17-2007 17:48:33
if it works and you don't intend to do any hard pulling I would leave as it is. If you intend to use it for pulling or hard work I would split the tractor to check it out.
Walt
