VAC oil
Big Billy Thomp
04-16-2007 14:43:27
Is 5w-30 good for a VAC engine?
Thanks yall
Big Billy Thompson
04-17-2007 11:56:16
 Re: VAC oil in reply to Big Billy Thompson, 04-16-2007 14:43:27
Thanks.I"m gonna go ahead and use it cause I don"t think it"l hurt it any.
Thanks
GEOM0
04-17-2007 08:02:03
I USE 5W-30 OR 10W-30 YEAR AROUND. MY DAD AND I HAVE USED SAME BRAND FOR APPROX. 50 YEARS WITHOUT PROBLEMS.
I HAVE BEEN TOLD NOT TO USE 10W-40, SMALL ENGINE MANUALS SAY NOT TO BUT 5W-30 IS OK.
THE ONLY ENGINE I HAVE HAD SEIZE HAD ROTELLA IN IT. I AM USING CIH IN DIESEL NOW, DON�T LIKE THE COST.
Big Billy Thompson
04-16-2007 17:03:58
Well, should I use it or get some 10-40. I"ll use it if it ain"t gonna hurt the engine but it"s some good Quaker stuff so??
I just used it in my truck and had some bottles left over and thought I"d ask around.
1stout
04-16-2007 15:59:02
5W-30 will be fine, but in the summer I usually switch to 10W-40. In case some out there don't understand multi weight oil here is an example of what it means. Let's take 5W-30 for example; when cold the oil acts like a 5W oil which helps in starting, when at operating temperature (200 F) the oil is 30W. This being said there is no reason to run a straight weight oil anymore, it just makes it harder to turn over.
Michael
mj
04-16-2007 15:47:24
I use it in the winter or 10-40, or 10-30 or ..... ?
H. Moyer
04-16-2007 15:20:02
I would never put that in my tractor.
Use Rotella sae30.
That is what I do in my Case SC
