870 case
jddeere
04-15-2007 19:31:37
i have posted several times before about this tractor. none of the gauges were working on the dash...havent been in a long time. I disconnected the wires at the sending unit on the fuel tank, temp sending unit, and transmission sending unit and when i ground them out all the gauges work. is it likely that all my sending units are bad or could it be something else. like i said the gauges havent worked in years.
GEOMO
04-16-2007 04:48:05
 Re: 870 case in reply to jddeere, 04-15-2007 19:31:37
YOU SHOULD CHECK SENDING UNITS TO SEE IF THEY ARE GOUNDED, SEEMS STRANGE THAT ALL ARE BAD.
IF SENDING UNITS ARE GROUNDED AND GROUNDING LEAD TO THEM MAKES GAUGES WORK, SENDING UNITS ARE BAD.
