inflating rear tire problems
mikecan
04-15-2007 12:48:06
iam pretty new with tractors i have a case 530 with fluid in the rear tires. The tire looks a little flat so i thought id put some air in the tire. When i put air in i could hear the air bubbling threw the liquid in the tire but after a bit the liquid looks like water started to come out of the valve stem near the bottom. I checked the tire pressure and it wouldnt register on the gauge. Not sure If my tire is flat or what when i drive it seems ok just looks like a tire low on air any advice what i should do i dont wanna wreck it by letting all the fluid our or something THANKS for any ideas
2545CASE
04-16-2007 16:19:51
 Re: inflating rear tire problems in reply to mikecan, 04-15-2007 12:48:06
The correct procedure to check the pressure and add air to a water (calcium Chorlide) filled tractor tire is as follows... First rotate the tire until the valve stem is at the top.. then check the pressure with an Air/Water certified tire tester and add air till you have the desired pressure.. usually 7 to 14 lbs. Most water filled tires do look a little low, that is their nature due to the added weight of the water in the tire. Notes... Yes they do make special air/water tire testers... since the water (calcium Chorlide) solution in the tire is basically salt water and is highly corrosive you need to wash the tester in clear water after use or it will corrode and never work again. Another note... The reasoning for having the valve stem at the top when checking is because the correct procedure for filling the tire with water is to never fill it above the valve stem when the valve stem is at the top. You need room for the air in the tire and since water does not compress, you are looking to test the air pressure. If you get any seepage of water, then corrective action needs to be taken sooner rather than later. A leaking tube will cause the salt water to corrode the rim and in a matter of months the rim will rust through. Also the valve stem is replacable since the salt water tends to corrode them. Many times when you test the pressure the stem will then leak so I always have a few new ones on hand to replace those that leak. To replace the stem, jack up the tractor, rotate the stem to the top, blead off the air and remove and replace the stem with a new one and replenish the air to the desired pressure. You should not loose any water that way. I know this because I worked for a tire dealer many years ago.
iowa_tire_guy
04-15-2007 19:41:21
You have a leak in your tube and the only place the air and water can get out is at the stem. I know many who live in denial and hope it will go away but it will only get worse. It is rusting your rim as we uh, type. The best repair is to replace the tube, fixing a tube with fluid in it is poor at best. And depending what you are going to use the tractor for you might just want to pump the fluid out of the other tire as well and go fluidless. (don't run ballast in only one tire, dangerous.) Easier on everything if you don't need the weight.
JGarner
04-15-2007 19:41:01
Before you break the tire down to remove stem or tube, go down to a commercial tire dealer or air conditioning supply house and get nome new valve cores. Could be the seal on the old valve core is leaking. These cores are very common, Shrader valves on air conditioners use them, all tires, the oilfield uses them in dome charged Gas Lift valve, etc. If you are going to try the valve core trick, jack the wheel up because even with the stem at 12:00 you will loose fluid when the valve core is removed and the tractor weight sets down.
These cores will be pennies and compared to the hastle of removing the wheel and tire from the tractor and then breaking it down you will be miles ahead to try the least expensive fix first.
Tom (Ks)
04-15-2007 14:30:58
Rotate the wheel until the valve stem is on top (at 12:00) then check with a guage. Fluid can damage a regular tire guage. If fluid comes out between the valve stem and rim, you may have a tube leaking. If fluid comes out of the valve core, you need to replace the core.
mikecan
04-15-2007 16:24:42
 Re: inflating rear tire problems in reply to Tom (Ks), 04-15-2007 14:30:58
that makes sense to rotate the tire. The tire was never leaking until i added air then it just seemed a little came out. If i were to have to change the stem as long as the stem is at 12 o clock then i wont lose all the fluid is this correct cause its not pressurised is it.. also would jacking the back of the tractor off the ground help to inflate tire easier Thanks for you input
Tom (Ks)
04-15-2007 19:29:31
 Re: inflating rear tire problems in reply to mikecan, 04-15-2007 16:24:42
All the fluid has to come out to fix it. The stem is part of the tube and if it is a tubeless tire, you still have to break down the bead to replace the stem from the inside anyway. Jacking up the tire to inflate is not needed.
