870 case problems
jddeere
04-14-2007 15:24:34
i am putting on new head gaskets and while i had to hood off i am wanting to get some of the gauges working. the tachometer has been broke for three or four years. I disconnected the cable on the dash and pulled the wire piece out and it is not broken so where should i look now. Also oil pressure gauge doesnt work. thanks in advance for your help.
dwag
04-14-2007 19:06:36
 Re: 870 case problems in reply to jddeere, 04-14-2007 15:24:34
If you spin cable by hand and tach ga. trys to work, tack drive is bad. Center of drive is worn or plastic drive gear broken (tach drive not turning with eng running) To remove drive, make a puller out of a 3\4 nf bolt. Oil press is picked up at port under starter, check line or guage.
0
