can you convert the 6 volt generators to12 volts
will in texas
04-13-2007 18:46:43
jut wondering if you can covert for 6 volts to 12 volts on the old generator
mEl
04-14-2007 04:43:21
 Re: can you convert the 6 volt generators to12 vol in reply to will in texas, 04-13-2007 18:46:43
While the purists will probably scoff, I simply set the vr up to 14 v on my bosses 54 DC , works fine, but it is a collector tractor and don"t get used.
dwag
04-14-2007 18:55:21
 Re: can you convert the 6 volt generators to12 vol in reply to mEl, 04-14-2007 04:43:21
Same mEL from past, that we miss and need on this Forum?
will in texas
04-14-2007 07:26:54
that is what I am talking about you gave me the answer i was looking for thanks i will see if it runs or burns up.
