engine timing
ken indiana
04-13-2007 00:50:19
In all the manuals it says to check the timing on a 1950 dc case tractor at the fly wheel . Ok I understand what to do to check the timing but , is this the rectanular plate on the side of the bell housing that has 4-6 bolts on it? Thanks for your help.
wilson
04-14-2007 06:54:52
 Re: engine timing in reply to ken indiana, 04-13-2007 00:50:19
when I do get the flywheel mark in plug hole on my cc puller I made a pointer on the front timming cover and made a knoch on the crank pulley. Makes it easy to use a timing light!!
Paul f
04-14-2007 07:57:03
 Re: engine timing in reply to wilson, 04-14-2007 06:54:52
Great suggestion!!!
Do you time her to run at 0 degrees (TDC) or do you find she runs better slightly advanced BTDC
wilson
04-14-2007 08:32:14
 Re: engine timing in reply to Paul f, 04-14-2007 07:57:03
since my mag is the old base mount with retard and advance I time at top dead center with a slight amount of retatd still on mag lever to crank start then can advance with mag lever to before dead center, If i cannot retard the thing will kick back when starting
amo
04-13-2007 06:45:08
when you find the mark spray a shot of red paint on it for future findings
Paul f
04-13-2007 05:45:05
No... Just forward of that plate is a pipe plug. (Below bump for the starter motor). Just remove it and you can see edge of flywheel....Note the guy who swung the hammer to punch the mark on my flywheel was either a 98 lb weakling or was very tired that day...Very faint looked more like a scratch than a punched mark. Incidently the easiest way to turn the motor over and watch for the timing mark is to use a wrench on the belt pulley. Of course Case used a 1-13/16 nut ...I am sure you have a socket that size laying around :-)...Good Luck
ken indiana
04-26-2007 02:28:25
 Re: engine timing in reply to Paul f, 04-13-2007 05:45:05
thanks for all the help this web forum is outstanding.
