I need a 930 engine will a 900 work?
Rickyp
04-12-2007 21:04:05
I need a good diesel engine for my 65 930 wheatland tractor. I have found either a late 900 or early 930. Will the engine out of this fit in my tractor? The donor tractor has compression release and mine doesn't. I want to make sure it fits. What do you think? Ricky
bradley martin
04-13-2007 02:57:00
 Re: I need a 930 engine will a 900 work? in reply to Rickyp, 04-12-2007 21:04:05
Is your 930 western a 6 speed or an 8 speed? If it is a 6 speed it will fit without any problem. If it is an 8 speed it will have adryclutch and the engine from the donor tractor will have a wet clutch. The crank on the wet clutch engine will be drilled to allow oil passage and theengine will lack a rear seal.
