Case 930 3 pt. problem
Schwebach
04-12-2007 14:58:15
The 3-pt. takes 15-20 seconds to raise. It seems as though it is building pressure to raise as it does not raise a little at a time but all at once. The remotes work fine without delay. I was wondering if anyone knew what the problem may be. Your help is greatly appreciated.
TomVAC
04-12-2007 17:06:26
 Re: Case 930 3 pt. problem in reply to Schwebach, 04-12-2007 14:58:15
Your 3 point valve under the seat needs to be taken off and cleaned. There is cover on the side with a bunch of parts inside. Take them out and clean housing. There is a steel ball that hangs up on dirt in the bore. Very common problem on 30 and 70 series.
