Case 930 Comfort King trans fluid fill location
Robert Hooker
04-11-2007 20:29:39
I have a 1965 Case 930 Comfort King and have drained the trans/hydraulic fluid out of all 3 drain plugs and have changed the filter. Do all 17 gallons of trans/hyd fluid go in the air breather/dipstick tube back by the PTO?
No tools
04-12-2007 07:04:49
 Re: Case 930 Comfort King trans fluid fill locatio in reply to Robert Hooker, 04-11-2007 20:29:39
Well You are right that is a contrapion of a dip stick.
What i have done on the 730s and the 1030 i owned was put the 17 gallon of oil in start them raise the lift arms.and shut r off.Then where ever the oil ends up at i set that little slide nearest to that then file a notch on stick right at the vary edge above the full mark.
Then one at the add mark
maybe that well help good luck least that will give you and ideal don't know their theary on that.
Bill
No tools
04-11-2007 21:38:41
Yes.
And at that it will probably show over full at first.
Bill
06-03-2007 16:59:48
 Re: Case 930 Comfort King trans fluid fill locatio in reply to No tools, 04-11-2007 21:38:41
Havent seen a dipstick, is this under the left foot in front ot the pto lever?
Robert Hooker
04-12-2007 05:46:48
thanks for the info, Bill. And you brought up another question I have. How do I tell what "full" is on that contraption of a dipstick?
