case 580CK model B
paul labas
04-11-2007 16:36:02
I have a 1975 case 580CK. when it is warmed up it will not go into foreward or reverse gear. when it is cold outside or the tractor is cold it seems to work fine. where do i start to look for the problem?? all the fluids are fine. it just will not go into gear when I put the shuttle lever into foreward or reverse. When it does finally go into gear it has no slippage or weakness at all. (this only happens when the machine is warmed up) I also sprayed cool water on the filter housing by the radiator and that worked for a little while. Please help!!!
paul labas
04-17-2007 15:40:36
 Re: case 580CK model B in reply to paul labas, 04-11-2007 16:36:02
is there a way to drain the fluid from the torque converter on this machine? Does it even have a torque converter? I took the drain plug out of the bottom and only got a bout a quart of oil out of it? My manual doesn't tell me.
paul labas
04-14-2007 10:33:02
where is the pump pick up screen located? is it something I can pull out and check without dismantling the machine?
jdemaris
04-12-2007 15:20:06
Have you checked all that convoluted linkage that operates the clutch-pressue to the reverser? I've had to fix several older 580CKs that would stop shifting when hot - unless you reached down with your hand and jerked on the clutch-pedal. 580CKs are also prone to plugging the intake-screen on the pump - but when that happens - the problem should be the opposite of your's. Bad when cold and better when hot.
paul labas
04-14-2007 11:20:29
 Re: case 580CK model B in reply to jdemaris, 04-12-2007 15:20:06
the linkage seems ok. there is no clutch pedal on this machine. just a foreward and reverse lever on the left of steering wheel. this is a forklift. the tag says 580BCK case
Larry V
04-11-2007 20:57:08
First I would check the adjustments on the clutch cut-out pedal, and the shuttle lever itself. Make sure the lever stops at the detents. There is a specific adj. for the clutch cut-out spool. It's possible the suction screen is plugged, a flowmeter would tell that. Hook up a gauge and wite down pressures cold/working, hot/not working, hot/working, and post results
Jim B.
04-11-2007 20:02:57
Of course the first thing to check is the filter condition and the oil pump pickup tube screen. Over years of use this screen can become dirty and cause restricted flow into the pump. Both filer and screen would have the same symptoms which can be verified by the process discussed below.
The 580CK Service Manual describes how to test the pump output. The regulated oil pressure must checked at a certain test port. If found too low there is a service part "shim" or spring replacement that can be installed in the pressure regulator to boost the pressure.
If your so inclined to do your own repairs I'd suggest you get the manuals and have-at-it. I bought mine years ago, thru eBay, and they have been invaluable. Owners, Parts & Service manuals are all published by Case. Don't waste you $ on non-Case books.
