580 B Backhoe
herald
04-10-2007 11:34:44
Where do you check the transmission oil on a 580B Bachhoe? I can't find any place or plug. Must be so obvious that I can't see it. Thanks
herald
04-11-2007 04:40:22
 Re: 580 B Backhoe in reply to herald, 04-10-2007 11:34:44
Found it. Thank you.
larry v
04-10-2007 19:57:18
under the floorboards near the steering column there is a plug (prox 1 1/4") in the trans case. Dipstick on plug. Should be an access plate to remove on floor plate to gain access
Mick K
04-10-2007 14:52:01
On my 580D there is a long dipstick on the right hand side at the back of the engine bay for the shuttle transmission and there is a dipstick under the floor for the gearbox. I would expect them to be in a similar location
Mick
