Factory oil press was 12 - 20 psi @ 1600 rpm @ operating temp. I would pull the valve cover, start the engine, and check for oil flow at the running gear. If no flow at the rkr arm brgs, I would pull the pan before going any further as the inner & aft cam brgs are lubed by top deck runoff. If you have oil there and running off the top deck down through the pushrod tubes, then there is no concern in running it for test purposes. The main brgs, conn rod brgs, front cam brg, gov assy, & rkr arm brgs are pressure lubed. The rest of the engine is runoff and splash lubed. Panel gauge is connected at the block oil gallery, make sure threaded opening (1/8" npt) in the block is not restricted. Use a 0 - 30 psi gauge right there. Pull the oil filter off, check that there is a tube about 3-3/4"L on the base that directs oil to the top of the filter media. Missing tube can drop oil press some if pump capacity is pretty much topped out. Oil pump pickup is a floating oil strainer, can get plugged, cocked or disconnected at the pivot (not likely). Oil pump internal wear, oil pump relief valve (spring), and/or worn bearings are the most likely cause of significant oil press loss. Joe
