L Clutch Disc - Same as LA??
pcheg
04-08-2007 16:57:24
Does anybody know if the clutch disc on an L is the same as an LA?
JoeBob/IN
04-09-2007 13:44:03
 Re: L Clutch Disc - Same as LA?? in reply to pcheg, 04-08-2007 16:57:24
You might try South Bend Clutch here in IN. They have parts for old Olivers in stock and probably old Case's too. I can get the phone number or try the link.
Don Livingston
04-09-2007 10:32:04
I sell them used or rebuilt.
Don L.
Bill Hires
04-09-2007 03:50:41
The Case parts books list identical clutch part numbers for the "L" and hand clutch "LA".
AllanC
04-08-2007 20:50:30
As far as I know they are the same except the '29 L and posssibly 30 had a different one. What year is your tractor?
pcheg
04-09-2007 06:42:41
 Re: L Clutch Disc - Same as LA?? in reply to AllanC, 04-08-2007 20:50:30
I have a 1937.
Ths hub splines are worn and there is a lot of slop causing vibration. I am trying to find a good clutch disc. This tractor is used for public demonstrations and I don't like the slopping around it does. Last year we split the tractor and checked everything in the transmission. Since I couldnt find a good clutch disc, I put the old one back in.
By chance do you have the part number for the clutch disc I need?
scott6143
04-09-2007 18:12:44
 Re: L Clutch Disc - Same as LA?? in reply to pcheg, 04-09-2007 06:42:41
just a word of advice, while you have the tractor split check the pilot bushing on the engine side, that is what caused the wear on the splines of my clutch and input shaft, causing a lot of vibration.
AllanC
04-10-2007 21:55:53
 Re: L Clutch Disc - Same as LA?? in reply to scott6143, 04-09-2007 18:12:44
yeah, and check the bearing on the clutch shaft where it mounts in the transmission. It needs to be tight. They are a single row bearing on the L. The LA went to a double row.
