Bosch ep/rsv300 injection pump
Laurie Levy
04-08-2007 15:10:36
I have a DB 1210 with Bosch eprsv injection pump. It appears to have an internal oil (?) chamber. Top screw cap has German (?) Oel printed on it. There appears to be a drain plug on the pump end.
Can anyone tell me what kind of oil and quantity goes in this chamber? It appears to be not diesel oil nor anything like 10 W 30. What if the tractor is run with this cavity low in volume?
TomVAC
04-09-2007 05:33:43
 Re: Bosch ep/rsv300 injection pump in reply to Laurie Levy, 04-08-2007 15:10:36
If I remember right you put the same oil in the pump as the motor. Should be a level plug. It's been 20+ years since I've been around these David Browns.
