dc smoker
johndeereman
04-05-2007 18:44:10
just had the head on my dc redone put it back on according to specs ran it for about an hour today buzzing some firewood when it got warmed up it started smoking bad (burning oil) thought that was strange didnt smoke before just had a burnt valve noticed it was pushing oil out of #2 exhaust port figured i had a broken ring or piston in #2 i pulled the piston out the bottom found the babbit that wraps around the rod was broke but the rings and piston look excellent could this be my smoke the piston was drenched in oil when i got her out but there isnt an oil hole in the rod so how does the piston get oil im assuming the crank has oil holes that shoot at the piston my theary is that the rod slops back and forth covering the oil hole giving the hole for the piston more pressure and volume is this logical or not im not familiar with the case engines oil system i know i need a new rod wich my buddy has some spares going to see him tommorow sorry for such a long post but ive spent too much money to have this tractor smoking pulling starts in 4 weeks and im not ready any info will be appreciated thanks, johndeereman
johndeereman
04-06-2007 20:35:18
 Re: dc smoker in reply to johndeereman, 04-05-2007 18:44:10
i should not need to worry about honing the cylinder or if the rings are upside down i did not touch the pistons just give it a valve job and toook a little off the head and another secret that im not giving out its not the head cause i had it on and running but head gasket didnt seal didnt smoke then only started smoking after bearing went a guy told me when the bearing went the babbit got hot and boiled the oil splashing it up on piston ill find out tommorow i got a different rod
wilson
04-06-2007 10:10:26
maybe I misunderstood but thinking it DID NOT smoke before valve job??? I do realize many time on higher rpm engines a valve job will create ring problems. However it might be like getting along with a woman, sometimes you dont know if it's something you did or something you did not do. I would carefully check the position of oil holes on the rocker arm shaft. Possibly oil is squirting directly on a valve stem ,especialy on the intake. If all else fails check with D C TOM as he has spent a lot of time with the D series motors.
C. Amick
04-06-2007 09:33:52
Did you hone the cylinder? The rings may eventually re-seat themselves, if they were placed on the piston properly?
bob eckardt
04-06-2007 08:25:31
Do you have the rings right side up and staggerd
the ring end on the piston.
