need some advice on 300
kyle boettcher
04-02-2007 19:43:40
I have spent a ton of money on my case 300 I have bought every thing new that I could. the oil pump has been custom built to factory specs out of stainless steel and oilite shaft bearings. I have replaced every oil seal and o ring possable, any way that was alot of work and I want to know what is the best motor, torque tube, gear case oil out there. oil lubracation seams to be a probelm on the 148 engine. Oil now days has got to be better now than in 1956. right?
1stout
04-03-2007 09:05:52
 Re: need some advice on 300 in reply to kyle boettcher, 04-02-2007 19:43:40
take a look at my post on here a few days ago about oil. Diesel oil has also had the additives (zinc)removed that is needed to lubricate the cam and lifters.
Michael
INCase
04-03-2007 09:25:57
 Re: need some advice on 300 in reply to 1stout, 04-03-2007 09:05:52
Interesting. I presume you can buy that STP additive anywhere.
1stout
04-03-2007 12:19:41
 Re: need some advice on 300 in reply to INCase, 04-03-2007 09:25:57
Yep, just regular STP, it's about a half a quart in a blue container sold almost everywhere. Or if you feel like spending more money Kendall oil is now called Brad Penn and is considered a race/off road only oil so it still has all the additives in it but it is only sold over the internet.
Michael
INCase
04-03-2007 05:12:00
Over on the Ford "N" board (2N, 8N, 9N) there was some discussion on the subject of the new oil formulations have removed some ingredients for "environmental" reasons and do not work well with non roller tapets. They were recomending diesel rated oils for all engines. FYI only check out that discussion for yourself.
