Follow-up on 310G with no oil pressure
jadpro
04-02-2007 16:40:57
I dropped the oil pan and pulled the oil pump out. There wasn't anything broken as far as the oil pump. I took the pump apart, and the gap between the gears or the lash is BIG. Also, the drive shaft bushing is sloppy too. You guys think this was my problem? If I stick the suction tube in oil and spin the gear, should it pump oil, or does it take a lot of speed? Anybody know where I can find an oil pump?
bradley martin
04-03-2007 02:48:24
 Re: Follow-up on 310G with no oil pressure in reply to jadpro, 04-02-2007 16:40:57
Spinning the pump by hand w/ the suction in a container of oil should pump oil.
1stout
04-02-2007 19:32:59
what is the casting number on the pump. I did one for a VAC and they just didn't have the quality of steel, machining centers, or heat treating that they do today. I ended up making new gears and a new shaft to rebuild the pump. Good luck.
Michael
