Adding 3 point to older 930 to LA
Camboted
04-02-2007 02:32:22
third party image
This is 3 point we added to a 930 six speed. We put the same units on the long nose but modify steering & brake pedals to move seat forward and higher.
coon hound
04-02-2007 10:31:02
 Re: Adding 3 point to older 930 to LA in reply to Camboted, 04-02-2007 02:32:22
If I read right,That 930 is a comfort king "western" .Had no 3-point,You install one from a regular 930,If so What all had to be done, I have 66 CK Western,Right now trying to find seal and bearing for/ to rebuilt water pump,Thanks
dctom
04-02-2007 08:08:39
TED ;; YOU ARE DOING WONDERS WITH THOES KIDS OVER THERE AND THE TRACTORS TOO, SURE GLAD YOU WERE RAISED A CASE MAN LOL KEEP UP THE GOOD WORK WITH THE ORPHANS AND HAPPEY EASTER TO YOU AND YOURS DCTOM
jim handke
04-02-2007 06:04:22
Ted, the rice paddies in Korea were small. One man worked them up with his ox. Granted, this was back in "72 &"73, but I would assume that mothing has changed drastically since then. Are the paddies in Cambodia that much larger that they can use your converted DC"s to farm? And that"s a good looking 930, by the way. Keep up the good work, I always look forward to your postings.
Jim Handke
Camboted
04-02-2007 21:43:25
 Re: Adding 3 point to older 930 to LA in reply to jim handke, 04-02-2007 06:04:22
Cambodia is extremly flat, thus the paddies are larger. Plenty of demand for tractors.
jim handke
04-04-2007 07:01:01
 Re: Adding 3 point to older 930 to LA in reply to Camboted, 04-02-2007 21:43:25
thanks, ted. never too old to learn.
TexasWren
04-02-2007 02:59:29
I really like the dozer blade. I could use one of those on my tractor.
Camboted
04-02-2007 02:33:37
third party image
Another picture of same tractor.
wilson
04-03-2007 10:57:04
 Re: Adding 3 point to older 930 to LA in reply to Camboted, 04-02-2007 02:33:37
should I call sonny about picking up the 900b????
