db 990 power steering
tractor junkie
04-01-2007 19:49:03
I just bought a '68 db 990 and it has a power steering leak on the cylinder itself.someone has beat up the housing where the lines connect as to where the o ring can't seal.I assumed it had hydrastatic steering because it said hydrasteer on the cylinder,but after looking on the case website,it has the power assisted steering.I need the tube(housing) or the whole cylinder, I think.any advice or help with parts appreciated.
Barry in KY
04-04-2007 09:59:49
 Re: db 990 power steering in reply to tractor junkie, 04-01-2007 19:49:03
We have a 1970 model 990. The power steering cylinder went out on ours, and my father just took a single direction cyclinder of the same stroke and size and drilled a small hole in the opposite end of the cyclinder (probably where the vent was) and turned the one direction cylinder into a two direction cylinder. He simply brazed a pipe fitting onto the side of cylinder the correct size to match the hose fitting. It worked like a charm, and we haven't had a problem with it in 10-15 years. No need to do any modification to the steering pump either. Probably cheaper than repairing the complicated original cylinder, but you do have to have another cylinder to start with. I think I still have pictures on my computer, let me know if you want a copy of them. [email protected]
Barry in KY
billh234
06-08-2007 07:10:59
 Re: db 990 power steering in reply to Barry in KY, 04-04-2007 09:59:49
Barry,
I just read your post and would appreciate it if you would send pictures. I've wrestled with leaks in my power steering assist cylinder for years, and replaced it with another one that I found at a tractor salvage yard only to have it leak as well. I'd be interested in seeing your fix.
Thanks. Bill
[email protected]
