massey sickle bar mower (pic included)
steven in tn
04-01-2007 15:20:55
third party image
i am having trouble with my old mower clogging up on the end with grass.are there any thing missing on the end?
jal-SD
04-02-2007 06:21:49
 Re: massey sickle bar mower (pic included) in reply to steven in tn, 04-01-2007 15:20:55
Steven, is that a #6 or #7 Massey? I have an operators manual for a #6 that I could copy & get to you if you don't have one. Spent MANY years mowing with a #6, it needs a ledger plate on the end & is the outer shoe OK? Both will make a big difference on how it works. (My $0.02 worth. jal-SD)
GEOMO
04-02-2007 06:18:47
I AGREE YOU MUST REPLACE GUARDS/LEGER PLATES; SHARPEN SECTIONS; SHIM AND HAMMER UNTIL SECTION CONTACT LEGERS EVENLY.
I MADE A HOLD DOWN ATTACHED TO THE TWO END BOLTS, MIGHT CHECK OUT "caseman-d" PART.
caseman-d
04-01-2007 20:03:32
Rowse manufacturing has come up with a piece that will bolt into the end of the bar for the New Holland and IH bars that they use on there mowers. Not sure if one will work on yours.
caseman-d
Klyde
04-01-2007 19:27:25
Get a 2lb hammer an beat all the guards up so their touchin the knives or so when you look down the bar their all in line. Replace the ledger plate in the swath head ,your second picture shows that it is worn out and rounded. If you cant find one at least take a grinder to it and square the edges. I still cut 25 acres of hay a year with a sickle bar as I havefor the last 35 years. I use a triple section on the end, used to get them from herschel. And I NEVER HEARD OF GRINDING THE POINTS ON A GUARD. Seems kinda stupid with the amount of rocks we have in upstate NY. But the most important thing you have to do is fix that end ledger.
flying belgian
04-01-2007 17:39:39
You need to replace all the gaurds showing except the red one. They are bent and the ledger plates are wornout. also make sure sickle sections are tight to ledger plate. May need to bend gaurds up a bit. looks like hold downs are new otherwise you can lay a bead of weld on them so they hold section down to ledger plate. Make sure wareplates are pushed forward when tightening hold downs. Sharpen gaurd points like a needle. Ledger plate in divider board needs to be replaced. Sharpen point on divider board. Sickle mower is a high maint. imp. but well worth the time to avoid frustration.
Don Rudolph
04-01-2007 16:57:12
I would bet good money that there is supposed to be some sort of guard over that last section (possibly held in place by that square head bolt that is dangling there in the cast end). A section without anything over the top of it is useless. That is the reason you have to quit cutting and put on a new section when the top of a guard breaks off-it starts plugging up immediately, especially in grassy hay. Don
Klyde
04-01-2007 19:39:39
 Re: massey sickle bar mower (pic included) in reply to Don Rudolph, 04-01-2007 16:57:12
That isn't a bolt thats the hook on on the replaceable runner that runs under the head.
Jwal10
04-01-2007 16:37:14
I would put a new ledger plate on the end , that one looks worn bad. I don't know that it can be sharpened , should just rivet on.As has been said a 1-1/2 section on the end will help. Some times you can put a piece of pipe on a guard to bend it up , down or sideways to make it as straight as possible and keep the section tight to the ledger plate. Also keeping sharper points on the guards wiil help keep grass from plugging.Another thing is with bottom serrated sections, a little sharpening will keep them cutting good....James
Dick in NY
04-01-2007 16:12:59
Steven Looks like the ledger plate under the cutter bar is rounded off. See if you can sharpen it with a file or small grinder. Also farm supply stores sell a section and a half that replaces the end section on the cutter bar that really helps to alleviate that problem. LOL Dick
Roger300
04-01-2007 16:04:14
The end section and the bottom section both look very dull, I would recommend putting a new serated edge section on the knife and try to improve the edges of the guard it rides on. Roger
stanley stenerson
04-01-2007 15:34:58
Looks like guard to the right of the red one is bent(near end of cutter bar) or out of line.
steven in tn
04-01-2007 15:34:04
third party image
1 more
steven in tn
04-01-2007 15:31:26
