CC Valve train
olone
03-31-2007 19:10:24
I have a CC with noisey valve train any suggestions on lubrication?
bradley martin
04-01-2007 09:52:10
 Re: CC Valve train in reply to olone, 03-31-2007 19:10:24
On my C , I put a piece of felt on top of the valve train, saturated w/ oil. It makes quite an improvementand no more stuck valves after sitting all winter.
L.C.Gray
03-31-2007 19:20:53
I use straight Lucas Oil Stabilizer. It'll stick around a lot longer than just plain oil.
olone
03-31-2007 19:55:43
 Re: CC Valve train in reply to L.C.Gray, 03-31-2007 19:20:53
Did you just put it on the valve train or in the crankcase.
L.C.Gray
04-01-2007 05:21:09
 Re: CC Valve train in reply to olone, 03-31-2007 19:55:43
Since the upper end of a C has no positive lubrication you must do it manually.
I use the Lucas because its gooey enough that it will stay in place for a weekend of tractor show use with just one application.
