870 lights
jddeere
03-31-2007 16:55:30
Lights havent worked on this tractor in years and i would like to have them working. Any advice for me. Also the pto runs all the time. if you are pulling a pto driven implemetn with the lever in the off position..such as a hay tedder it will slow it down in heavy hay but not stop it
PORKY B.
04-02-2007 19:20:08
 Re: 870 lights in reply to jddeere, 03-31-2007 16:55:30
SORRY did not read your post clear enough .PTO not shutting off with implement could very well be the pto valve if it is a powershift model.
PORKY B.
04-02-2007 19:12:04
your pto problem likely will be a wore out brake .
justanothercase
03-31-2007 17:17:36
lights-check power from ign. switch to light switch. make sure power wire to light itself isnt shorted out too.
pto- if its a powershift it may just be a valve letting hyd. pressure by. could take the clutches out if not fixed.
My 2470 had what sounds to be the same light problem. I had power at the wires to the ign. switch, but when i crossed them to the lights nothing happened. I ran a new power wire and the lights worked perfectly. case wiring is a real mess, they could have saved themselves money by simplifying it. hope i was able to help good luck
