rod bearings
jadpro
03-30-2007 09:07:10
When I drop the pan on my 310, I thought about putting bearings in it to. Should I go with standards or undersize bearings? I know I can get .002 under, and I can get some .001 under for the rods. The mains I am going to go with standards, unless the crank needs to be ground; then I will have to go with undersize bearings for that too. I guess I should mic the crank first. Just wondering what you guys thought. I see that for some tractors, you can only get undersize bearings starting at .002 under.
Joe (Wa)
03-30-2007 09:29:32
 Re: rod bearings in reply to jadpro, 03-30-2007 09:07:10
If the crank is still in the engine, liners & journals look pretty good, I would check the clearance with leads or plastigage. Journal taper is important also, you can see an indication of that in the liner wear and measure it with your leads. Check crank runout at the inner thrust collar.
Joe
