fuel gage sender
INCase
03-28-2007 15:00:01
A while back I recall someone suggesting that a replacement fuel sender for 700-830 fuel tanks could be had at Napa. Does anyone know what "vehicle" to look up the part number or the Napa part number? Thanks.
dboll
03-30-2007 05:01:44
 Re: fuel gage sender in reply to INCase, 03-28-2007 15:00:01
not all were SW, some 30 series had Auto-lite gauges
Roger300
03-30-2007 04:44:25
The part number from NAPA is TS6726, that's for a right hand swing one, if it needs to swing to the left is a differant number. It's a stewart warner gauge and has directions with it on how to set it up. Good luck, Roger
dboll
03-29-2007 05:10:37
case has senders for the early 30's, I am sure they have them for all 30 models. I bought two for my 61 830 and can't make either one work right, tried differen't gauges, external grounding ect. even called teleflex (the maker) any ideas appreciated
wisconsinBill
03-28-2007 17:42:44
I get lots of tractor parts at NAPA and I tell them the model of my tractor that they then look it up. Some parts are dealer only, I have also found. Then my Case dealer looks it up and sometimes says that CAse no longer has that part and I need to go aftermarket or junk yarding. Good luck, but as in some cases, I also found out that the tractor still runs without that 'special' [expensive]part!
