Tool Gauge for Magneto
Dan Owens
03-28-2007 13:51:21
I'm looking for a tool. It's a guage for a magneto for a 1948 Case LA. I think it is used to set the timing on the magneto. The part number is 04738AB in the parts manuel. Anyone know where I can get this little tool?
Walt Davies
03-30-2007 09:03:05
 Re: Tool Gauge for Magneto in reply to Dan Owens, 03-28-2007 13:51:21
after you get to that point you can time it right on with a timing light.
I timed mine at 30 degrees BFTDC at full advance.
On the main pulley put two marks on the pulley and the block when you have it on TDC then measure out 1.5 in. from that mark on the Pulley and put another mark this is 30 degrees. then hook up your timing light and set the mag so the marks line up.
make sure the mag is at full advance. Walt
Give me a call if you need help 503 623 0460
Dan Owens
03-30-2007 10:52:39
 Re: Tool Gauge for Magneto in reply to Walt Davies, 03-30-2007 09:03:05
Thanks, Walt. I'll do it!
DKase
03-29-2007 10:48:29
From my experience the gage would only confuse you. I have yet to take one of these old tractors appart that the governer gear is timed properly with the timing gears so the gage you refer to would work. All you need to do is get #1 cyl. to TDC on the compression stroke, and make sure the rotor is aiming at the #1 spark plug wire. From there it can be timed by your ear. Good Luck DK
Dan Owens
03-30-2007 05:05:58
 Re: Tool Gauge for Magneto in reply to DKase, 03-29-2007 10:48:29
Thanks, DKase! Now that's good advice and that's why I come to this board.
