repairing tubes
steven in tn
03-28-2007 09:01:33
is any one having trouble patching tubes?
or am i the only one.
we are doing nothing different we did 30 years ago. the problem were having is when i put the patch on i can peel it right off. its like the glue is bad and the patch will not bond .
i have tried 2 types of glue and several kinds of patches with all same results.
Walt Davies
03-28-2007 19:11:28
 Re: repairing tubes in reply to steven in tn, 03-28-2007 09:01:33
I guess we are not the only ones having trouble I took two tires in to the local shop and one held air and the other didn't. I guess that's what you get for free work.
Walt
Gene Dotson
03-28-2007 16:36:43
It is very possible that your patching material is too old. New material is only partly cured and finishes curing after installed. It further cures as it ages in the package and after about 2 years it is no longer useful.
My method oc patching tubes it using a corner of my welding table that I usually keep clean. I have a piece of 16 gauge sheet metal channel about 10 inches long and 3 inches wide. I buff the tube to clean rough rubber and apply the glue. (the glue does not suffer with age). I then lay the tube flat with the patch up, lay the channel flat on the patch and clamp it to the table with a pair of welding vise grips. Then with a torch I heat the channel to just a little more than a comfortable quick touch. Allow the angle and tube cool completely before removing the clamp. You will have a patch that has been vulcanized to the tube with sides blended to the tube surface... Gene
dctom
03-28-2007 11:15:26
IF AFTER THE THIRD TRY I ALWAYS GO BUY NEW TUBE LMFAO
DKase
03-28-2007 11:08:49
I have better luck with the cold patches on heavy tubes. Buff them off really good. Put the liquid patching stuff of till it is just damp. LET IT DRY! I hang them over my vice with a light bulb 1/2 inch from the hole to warm it up. I have seen guys light the liquid on fire. A couple minutes later when it is warm and dry roll the patch on really good. I have never had one leak this way. DK
