830 problem
napaguy
03-28-2007 05:19:27
i have an 830 diesel 4 speed with hi and low (not case o matic).when i start it it will not move. shifter seems to be stuck between gears. it does not want to move when i release the clutch.hi lo selector will grind without the clutch so im assuming the clutch is working.any ideas? napaguy
bradley martin
03-29-2007 02:28:18
 Re: 830 problem in reply to napaguy, 03-28-2007 05:19:27
Hi Napaguy; The top cover lifts straight up but depending which model you have there are a number of other items that have to be removed first.Some you will have to support the steering column because it is attached to the cover which entails removing the dash and laying it forward on the fuel tank.Likewise, the seat and support needs to come off.It is not a 1 hr job but once you get into it,it goes along not too bad. LOL
dwag
03-28-2007 19:24:07
Unbolt and remove shift lever from trans cover, and line up shift forks with a LONG screwdriver\prybar. Looking thru hole, you"ll see one out of whack.
John Saeli
03-28-2007 17:43:09
If you think it's stuck between gears, I don't think you have any choice but to pull the cover. Good luck.
napaguy
03-28-2007 19:12:51
 Re: 830 problem in reply to John Saeli, 03-28-2007 17:43:09
john, i haven't done anything with it yet. after i take the floor plates off does the transmission cover come off from the top like an 8n or to20? those are the only tractors i have ever been into as far as transmissions go. thanks,terry
