Case VAC gear oil leak
Cary Kennedy
03-26-2007 20:57:25
Good day,My 1952 Case VAC has slow but steady gear oil leak between seal and axel as it exits the case, my rim is always coated with gear oil. How do you extract that seal for replacement? All ideas welcome.
Wait a min .. Joe (Wa)
03-27-2007 13:38:12
 Re: Case VAC gear oil leak in reply to Cary Kennedy, 03-26-2007 20:57:25
What am I missing, are older VAC's different? My 53 has flooded axles. Looks like all you have to do is pull the wheel, jerk the old seal, clean up the shaft, and pound in a new seal.
Go to the link and click on page G5 D1 & D2.
Augie
03-27-2007 18:59:09
 Re: Case VAC gear oil leak in reply to Wait a min .. Joe (Wa), 03-27-2007 13:38:12
I've done the job. I can assure you that removing that seal with the axle still in the housing would be a chore. Removing the axle is not a difficult job. Remove the wheel hub, pull the PTO, remove the axle nut, slide the axle out.
Joe (Wa)
03-27-2007 21:05:58
 Re: Case VAC gear oil leak in reply to Augie, 03-27-2007 18:59:09
Well Aug, I haven't done a VAC axle seal but have done many similiar seal replacements. I've always found it easier to install a seal with the shaft in place when possible.
I guess it is just a matter of whichever way floats your boat.
Joe
F-I-T
03-28-2007 10:47:53
 Re: Case VAC gear oil leak in reply to Joe (Wa), 03-27-2007 21:05:58
Joe:
I replaced the seals in my VAC and I just used my slide-hammer-with-a-screw-on-the-end-screwed-into-a-small-hole-drilled-in-the-seal-tin-shell method, and it worked just fine.
I didn"t want to fuss with the axles if I didn"t have to.
Frank
Joe (Wa)
03-28-2007 15:12:33
 Re: Case VAC gear oil leak in reply to F-I-T, 03-28-2007 10:47:53
Hi Frank,
Yeah, the screw works good most times, I been using the hardened hook adapters on the hard ones. Augie is probably just used to working on them ornery MO tractors.
Joe
Cary Kennedy
03-27-2007 11:58:54
thank you,Augie and Jim for the guidence.
Augie
03-27-2007 09:35:59
The axle needs to come out first.
J heitkemper
03-27-2007 07:35:13
The choice is YOURS ,. Before you tear it down ,,If You have LUCAS Hub Sealer in your auto parts store , Put that in your tranny , It may swell up the old seal and give it new life .. Good luck .. Jim
