Eagle Hitch won't lower
Tom Railsback
03-26-2007 14:24:42
I can't get the Eagle Hitch on my 1951 D to lower. I was told to take the rear cover off and look to see if the setecrew holding the arm to the shifter shaft was tight and it is. I'm thinking it might be in the cylinder becase it doesn't look as if it was put together correctly-has a dent right at the top and the end is not tight against the barrel. If that's the case (no pun intended), I'm O.K. as I just bought a cylinder off Ebay and I'll simply change it out. If not, what should I check next?
tom stanley
03-26-2007 20:31:57
 Re: Eagle Hitch won't lower in reply to Tom Railsback, 03-26-2007 14:24:42
Tom will call you in the morning to go over prob Tom
