how to tell a vac case
oliver1650
03-25-2007 19:27:17
i am looking at a case that looks to be a vac case, but it is a wide front. were they called vac's or is there a different model name for them. also what is it worth w/ eagle hitch and stuck engine. also where can i find the serial number on these tractors so i can find the year. anything greatly apreciated!! thanks
oliver1650
03-26-2007 11:19:45
 Re: how to tell a vac case in reply to oliver1650, 03-25-2007 19:27:17
do you guys know what one is worth restored and looking good??
thanks kyle
Jerry W
03-25-2007 20:10:52
If the wide front is non adjustable then it is either a VA or a VAI. Widefronts on VAC are adjustable and are either overlapping Ibeam construction (early) or telecoping tube (later)
mj
03-25-2007 22:22:10
 Re: how to tell a vac case in reply to Jerry W, 03-25-2007 20:10:52
third party image
Jerry- The VAC was standard with non-adj. wide or narrow front. The 'extensible' wide front was an option as was the single-front. The non-adj wide front on the VAC had the same front hubs and 3-
bolt wheels as the 'extensible' wide front while the VAO and VAI had a one piece wheel and different hubs. If you look in the 'Special Equipment' section in the photo you will see the 'extensible' wide front and single-wheel options. I have 3 extensibles, one narrow front, 2 single fronts and a non-adj wide front with 32" rears; all are VACs. They all fit the description above and agree with the spec. sheet on the link. :-)
TimBinWV
03-25-2007 19:40:40
Oliver,It's not uncommon for a VAC to have a wide front. The serial tag should be on/near the dash panel. I have a 54 VAV-14 that's got the eagle lift,and wide front. It's steering wheel is offset,kinda weird...from the factory. Dunnoo what one's worth with a stuck engine,but I gave 500 for mine with the engine needing rebuilt,and partially disassembled. It's got good rubber on the back,at least!!I've been told that 54or55 was last year of production for the VAC...
