400 power steering problem
Scott KY
03-25-2007 17:06:14
I used my recently purchased 400 diesel at a plow day yesterday. The power steering works OK but the front wheels quiver when I put any pressure on the steering wheel. I am going to change the fluid and filter tomorrow. Any ideas what to look for? The wheels turn easy and the belt is tight.
Gene Dotson
03-25-2007 20:05:51
 Re: 400 power steering problem in reply to Scott KY, 03-25-2007 17:06:14
Scott;
You may have to adjust the free travel of the steering shaft. Remove the front casting cover to get access to the round cover with 3 bolts. Remove this and you will see the end of the shaft with 2 nuts and a locking ring. Loosen the outer nut and with a dial indicator, adjust the inner nut so you have .045 travel forward and back when turning the shaft by hand with the engine not running. You can also do this with stacked feeler gauges. This should take out the shimmy... Gene
