Ok, if the draft arms stay up with weight when that valve is closed the leak down problem is in either the lift check valve or the release valve. The link below is mj's service manual. Click on page G7 D3. Fig D-6, see the check valve assy. The ball & spring is accessed by removing the hex head plug on the bottom of the control valve. Look for the obvious, corroded ball/seat, broken spring, etc.. The release valve is more likely the culprit, the plunger on the newer 2 stage valves sometimes just get stuck in the release position. For orientation click on page G7 D2, the release vl plunger is on the left toward the back of the tractor. To access the valves actuating lever and plungers follow the removals on pg G7 D6 and stop at the end of that page. Shims are important, especially the ones depicted Fig D-17. Now go to pg G7 D13, fig D-39, see the .010� lash. You will be able to determine if the plunger is stuck. If you push it in the spring should pop it right back out. Read the next few pages on adjustment before going any further. If the plunger isn�t stuck or cannot be freed up, you will have to go back, complete the removals and split the 2 halves of the control valve block to access the valve, spring & ball. While you have the block apart checkout the other valves. Joe
