990 selectomatic clutch
Jeff Mc
03-25-2007 07:11:29
Well you get what you put into it I guess. My clutch was shot last year and I finally got it into a shop in early January - trouble is the tractor is still there and is still not fixed. I'm hoping that I can get some guidance from some of the folks on this board to help when I go into the shop on Monday. Here is the info I have, the clutch was completely replaced, it was metal on metal and they had to machine one of the plates. After they put it back together the transmission won't slow down enough for to switch gears. Apparently there is a brake band that fits over the input shaft to the transmission that has worn out and the part can't be found. We've also discovered the steering housing is cracked and that needs to be replaced. Its my understanding that the clutch on DB 990's can be tricky. Here are the questions: 1) Where do I find a brake band? Is there another fix to this? 2) How long should a job like this take? 3) what should be done about the steering, do I need to buy the entire assembly?
All your help is GREATLY appriciated -
Davebr
03-25-2007 08:06:03
 Re: 990 selectomatic clutch in reply to Jeff Mc, 03-25-2007 07:11:29
I just bought that part from my Case Dealer. Most all parts with a few exceptions can be ordered from you Case dealer. When you go to the dealer give them the part number but put a "K" in front of the part number or tell them to do it. I would think with waiting on parts this job should take at most a month. Also to answer any of your other questions email Elmer @ [email protected]
Good luck,
Dave Brown
[email protected]
Jeff Mc
03-25-2007 11:19:21
 Re: 990 selectomatic clutch in reply to Davebr, 03-25-2007 08:06:03
email has been sent to elmer. Thanks for the help.
