930 Diesel Overhaul update
CNESLER
03-24-2007 15:30:51
I have the 930 diassambled and sleeve's pulled.
piston 1 had a broken ring
piston 2 all the rings were stuck
piston 3 the land between the rings was broken
piston 4,5 and 6 all looked normal
the crank was 2.749 right on spec. for standard
bearings. Now all I have to do is clean everthing
up and wait for my parts to be delivered.
CNESLER
DKase
03-24-2007 18:11:13
 Re: 930 Diesel Overhaul update in reply to CNESLER, 03-24-2007 15:30:51
Make sure you get the valve protrusion right to spec. The valve down in the hole can even be a little higher than spec. If they are down even the slightest it will start hard.
