terra trac Case crawler
Randy Schultz
03-24-2007 05:16:08
I would like to know if anyone knows when Case made a small bulldozer - I have a Case bulldozer that is has a 4 cylinder gas motor and says "Case" on the side of it but I can't find a plate anywhere on the machine that lists the serial number, etc. Does anyone know where to find this? Also, would like to find a manual for this machine, what year it is, and anything else about it - any help would be appreciated.
Gene Dotson
03-24-2007 08:49:37
 Re: terra trac Case crawler in reply to Randy Schultz, 03-24-2007 05:16:08
Randy;
Look on top of the left hand frame rail about 16 inches from the front. The model and serial number will be stamped there. If it is a model built after Case bought Terre-trac, there should be a serial number tag fastened to the outside of the left armrest.
Case bought Terra-Trac in 1957. Early models used Continental F-series flat head engines. Later models used the Case built 148 gas and 188 diesel engines. If it has the Case name on the decal it is likely a 310 or 320... Gene
