Case SC oil filter leak
Dug G.
03-23-2007 23:42:56
Our SC recently started to leak oil from around the retaining bolt in the center. Anyone have any suggestions or experience for a fix? I thought maybe a oil passage problem, but pressure remains steady, not overly high, or at zero. Looks like there was some sort of seal or washer around top, but how do you replace? I can"t find a way to get the bolt off of the retainer under cap. Thanks, Dug
J heitkemper
03-24-2007 03:18:19
 Re: Case SC oil filter leak in reply to Dug G., 03-23-2007 23:42:56
Had that problem a while back ,.Shucks ,Can't remember how I got that thing off there ,,But I Did ,, And replaced the worn out washer with same , that was home -made out of My archives shop .btw .My 54 Sc Or none of the other sc's I have hanging out around here ,did not come with a filter . problem came about when I put a salvaged DC filter canister on the Sc ..... Little history fact .CASE CEO Clausen Claimed they did not need them ! ... Sure had a lotta faith in CASE motors ! ,,GOOD Luck , Jim
Dug G.
03-24-2007 22:13:17
 Re: Case SC oil filter leak in reply to J heitkemper , 03-24-2007 03:18:19
I got it off today, used a punch to drive the bolt/shaft thru the top, in the process it straightens out the retainer ring thing on the bottom.
Thanks, Dug
