SC transmission case leak
SDLars
03-22-2007 06:15:09
I tightened the drive chains on my SC and now even though the transmission case is drained, I'm getting a leak. Anyone have any sure fire shortcuts to regasket this piece? Can I loosen the bolts holding the axle housing to the trans case and slide a new partial gasket in? I just had the bolts loose enough to tighten the chains and thought I'd ask you guys before I go any further. I want it ready for paint soon.
Gary in Pulaski, WI
03-22-2007 09:48:31
 Re: SC transmission case leak in reply to SDLars, 03-22-2007 06:15:09
I have had much success with using a technique that follows. I have used it with partial gasket replacement, and even with no gaskets. First thoroughly clean the surface to be sealed. Both sides/surfaces. Clean finally with a good spray type brake cleaner. After it dries, apply G.M. assembly adhesive (part #012346192)(available at G.M. parts counter) according to the directions on the tube. The small tube is sort of expensive-- $12.00, but it has NEVER failed me. Your welcome
SDLars
03-22-2007 13:38:30
 Re: SC transmission case leak in reply to Gary in Pulaski, WI, 03-22-2007 09:48:31
Thanks Gary. I've used a similar approach on other pieces but what I'm wondering now is if I can get enough room to do that just by taking the bolts loose that hold the axle housing to the transmission case or if I'll need to dig further.
