Winch / Tractor
timice
03-21-2007 05:57:15
I just bought a 8000 lb winch that I mounted to a reese hitch plate that plugs into my F-150. I would also like to use it with my case 540. I am thing of welding a female reese hitch that would slip over my draw bar or create a 3pt reese hitch. Does any one have any experience with these types of set ups or advice for using a winch with a tractor? All comments welcome. Thanks
JRT
03-21-2007 21:47:32
 Re: Winch / Tractor in reply to timice, 03-21-2007 05:57:15
If I were you, I would somehow mount it on your 3-point hitch so you could let it up and down and have more control over it. Also if you need to pull much with it you need to design it so it will plow in the ground against your load when you are pulling. If you don't, with a tractor only the size of a 540, any load at all will just drag your tractor around. I suppose it would be o k if you were only going to winch in small stuff. With a winch, the heavier the tractor, the more you can pull. I have one on a 730 with 18.5 X 34 tires with weights and tires loaded. It will pull one more load and the tractor will sit still. It is a very handy piece of machinery.
TimBinWV
03-22-2007 05:02:27
 Re: Winch / Tractor in reply to JRT, 03-21-2007 21:47:32
JRT has the right idea. A friend of mine had one mounted on a 3pt that had a floating "leg" trailing behind it that would keep the tractor from being dragged backwards...and it was short enough to be picked up off the ground so he could back up when necessary.
BCnT
03-22-2007 08:23:54
 Re: Winch / Tractor in reply to TimBinWV, 03-22-2007 05:02:27
i got a piece of plate on top of my box blade that winch mounts on...sink that baby in and winch anything ya want
