Case 1390, a.k.a. David Brown 995
Ron of Wisconsi
03-20-2007 20:26:39
I am looking at buying a Case 1390 diesel 4WD.
Any comments? Good points? Bad points?
I understand that Elmer may be the guru. Elmer, are you out there?
Elmer
03-23-2007 04:43:32
 Re: Case 1390, a.k.a. David Brown 995 in reply to Ron of Wisconsin, 03-20-2007 20:26:39
Decent enough tractor. If you put a loader on and depends on the lift cylinder size you may want to beef up the front axle. The hydraulic capacity can break the axle at the trunion pin. We used to add a "C" channel under the axle to strengthen it. I put a 1200 axle under my 990. My loader will lift 3000 pounds. 1390 has the same axle as a 990.
Ron of Wisconsin
03-26-2007 16:23:45
 Re: Case 1390, a.k.a. David Brown 995 in reply to Elmer, 03-23-2007 04:43:32
Elmer,
Do I understand correctly that this tractor has only one hydraulic outlet? If so, does this mean that it is not possible to put on a loader with both hydraulic lift and hydraulic positioning of the bucket?
Ron
Ron of Wisconsin
03-25-2007 18:13:06
Elmer.
Thanks for the reply and the advice on the front axle. Do you have any idea what the loader lift limit might be with the production axle?
I understand you might be the guru of this vintage of Case tractor, so I would appreciate your comments.
Ron
