to John Saeli,
Kirk in Ks,
03-20-2007 17:06:14
The back steering on my 2670 is stiff, or wonnt work,
tried to move the handle, but wouldnt move.
John Saeli
03-20-2007 17:17:33
 Re: to John Saeli, in reply to Kirk in Ks,, 03-20-2007 17:06:14
Hey Kirk: I'm not familiar with the rear steering on the 70 series. Someone will chime in & help. Good luck!!
Kirk in Ks,
03-20-2007 21:16:21
 Re: to John Saeli, in reply to John Saeli, 03-20-2007 17:17:33
Hi John,
the 2470, 2670 all had crab steering and your,s does too like mine,
I was wanting to try it out but it kind of vibrated a little bit when i tried to move the lever,I think it,s just a little sticky from non use,
Kirk,
John Saeli
03-21-2007 05:53:21
 Re: to John Saeli, in reply to Kirk in Ks,, 03-20-2007 21:16:21
Hey Kirk: Our tractor is a 4690. The rear steering is electric controlled.
Jim B.
03-20-2007 22:06:16
Kirk,
The Rear Steer on the 24,26 & 2870 is intended for field use only. The hydraulic system does not permit the rear steer feature to function until 15-1800 RPM & higher. The in-opt and vibration is normal at low engine speeds. If you want to use the rear steer to easy-align the drawbar or 3-point lift arms to an implement then you must push in the clutch (inching pedal) and rev the engine a little. It's in the service manual.
Just FYI... the Apostrophe key (') is the one just to the left of the Enter key. The Comma key (,) is different than the Apostrophe key. It's just to the right of the "M" key.
