C and DC manifolds
mshultz
03-20-2007 15:50:38
I have a distilate manifold on my C that I'd like to replace with a gas manifold from a DC. The exhaust manifold is paper thin or blown out on most of the gas manifolds that I've found. I haven't been able to compare, but does anyone know if the intake from the DC gas would bolt up to the exhaust of the C distilate manifold? If not, anyone have a good gas manifold you'd part with?? Is there a manifold out there that would be better than the gas manifold?
Thanks!
wilson
03-21-2007 12:06:45
 Re: C and DC manifolds in reply to mshultz, 03-20-2007 15:50:38
years ago I wanted better flow intake wise . I took a dc intake to local machine shop and had it drilled out 1/16 inch larger ( there is plenty of metal to do this on a DC) this seemed to help a lot with 400 carb which will bolt up to a DC . Mo TEC engieering at tipton ind has done real good on carbs for me also, and a good fellow to work with. Run 32 inches of exhaust pipe fron the exhaust valve to the top of exhaust and index the sparkplugs. Makes those 2 cylinder tractors run to find a hole to hide in.
wilson
03-21-2007 08:13:11
I have a couple of used dc manifolds to sell as need to clean out my stock (junk. Why not just change both together??
mshultz
03-21-2007 08:52:40
 Re: C and DC manifolds in reply to wilson, 03-21-2007 08:13:11
I'd change them both together if the price was right and in decent condition. My exhaust seems fine, I'd just like to get a little better air flow and temp, and I've been told the gas manifold will perform better. The manifolds that I've seen have a decent intake, but the exhaust needs to be replaced. I see new exhaust manifolds for sale on e-bay for around $180 which is great, I'm just trying to find the most inexpensive solution.
I might be interested in an entire manifold. E-mail me with details.
wilson
03-21-2007 11:56:50
 Re: C and DC manifolds in reply to mshultz, 03-21-2007 08:52:40
I will trade you even as I plan on redoing my C-C at some point in the future, I have been saying this for 3 years now , but I really do plan on it this fall. I am sure I have a good set as I looked this AM and have them off a 52 DC.lets trade the whole thing exhaust and intake. Would it be fair to ask you to pay the freight both ways? 307 532 3999
Brian in Ohio
03-20-2007 17:19:17
THe basic answer to your question is... Yes, the intakes will interchange.
If you don't want to spend the $$$ for a new one, you might also check with Don Livingston to see if he has a good used one.
How solid is your distillate intake? If it's in usable condition, I might be interested in it for my CC.
mshultz
03-21-2007 08:54:42
 Re: C and DC manifolds in reply to Brian in Ohio, 03-20-2007 17:19:17
I'll try to get a picture of it and e-mail it to you to check out. If I can find a replacement to go in its place I'd part with it with no problem.
Thanks.
C. merchant
03-20-2007 16:40:36
John Saeli stocks new minifolds. They fit everything from the 29CC to the 54 DC. 315-585-9826
