Look at swing cylinders again
Roger (Mi)
03-20-2007 05:34:32
Since the swing cylinders were the last items being worked over, better check there first. Damaged seal during assembly? Loose piston rod nut? There are criss-cross reliefs on the swing cylinders that allow oil to transfer from one side of the hydraulic cylinders to the other. Because the boom is so heavy (especially loaded with dirt), those reliefs open on sudden hydraulic stops to prevent system damage. Unless there is some foreign matter preventing those reliefs from operating properly, your problem will likely be found in the cylinders.
Ed's 530
03-21-2007 09:20:48
 Re: Look at swing cylinders again in reply to Roger (Mi), 03-20-2007 05:34:32
I found the problem. The stud at the end of the rod cracked just where the threads start. Do you think this is from the nut being too tight? When I rebuild how tight should the nut be? Thanks
Roger (Mi)
03-24-2007 05:21:02
 Hydraulic cylinder piston rod stud torque in reply to Ed's 530, 03-21-2007 09:20:48
There are charts available listing the proper amount of torque a nut or stud should have given its size and hardness. Example: 5/8 stud with grade 8 hardness should have 200 to 240 foot pounds of torque.
