Case VAC w/ Duals??
TSS
03-19-2007 17:03:27
Thinking of playing around with an extra set of VAC tires and rims and was woundering will I need anything special to mount another set of wheels on a Vac to give it duals other than what you see on a standard one wheel axle set-up? Any info would be great. Thanks
TSS
03-20-2007 19:09:39
 Re: Case VAC w/ Duals?? in reply to TSS, 03-19-2007 17:03:27
Thanks for for the info and remarks. I will defently post some pics when done. Should be pretty tough looking for a little tractor when done. I'll make sure to be easy on the clutch.
TimBinWV
03-19-2007 17:23:41
I don't think you'll have any trouble putting them on,but you may create trouble if you try pulling something too big w/it. The offsets should work out for spacing of the wheels...you may need to move your fenders in as close as you can get them...Good Luck,and post a pic when you're done!
Glenn F.
03-20-2007 09:55:47
 Re: Case VAC w/ Duals?? in reply to TimBinWV, 03-19-2007 17:23:41
Yes. It would be a novelty, but just about as practical as half-tracks on an 8N Ford. You better have an extra clutch on hand.
Glenn F.
