case 960 combine ?
pa dave
03-16-2007 17:04:27
looking for any info on the 960 combines, we are looking at one next week, it has a grain head, one question is did they make a corn head for these and if so where could a guy find one? would appreciate any facts, + or - about them. Thanks
Bill from wisc
03-19-2007 08:35:24
 Re: case 960 combine ? in reply to pa dave, 03-16-2007 17:04:27
The 960 machine was a good machine in there day. As stated below the case corn heads had a lot to be desired. I dont own a 960 but own a 660. 1160 and a 1665 In beans or small grain you can not beat them for cleaning. Even in corn they are good. You could convert a Jd feeder housing onto them to accept other model heads. I dont remeber the clyinder with on the 960 tho a Feeder housing from a 45jd fits the 660 and a feeder from a 95 fits the 1060 and 1160 and a feeder housing from a 105 fits the 1660 and 1665 machines with a little work. Check the sheet metal under neath the machine and exhaust manifold and go from there. good luck Bill
Mark N.
03-18-2007 18:47:15
We had 2 of these when I took over the farm from Dad and I couldn't get rid of them soon enough. Because of the design of the corn head, the trash would build up in the "trough" and couldn't get to the header cross auger which was under a tin cover. If you have any corn with weak stalks or down corn, you will be sick of the head. I tried to find a way to put an MF head on but traded machines instead. Best thing I ever did. On the plus side, this machine was great on beans.
jim handke
03-16-2007 19:06:03
We still have ours and it"s been a darn good machine. It could be equiped with a 3 row narrow row corn head or a 2 row wide. There were two styles of corn heads. The early model had two augers to take the corn up to the cylinder, steer clear of that one. The later one had a regular feeder house chain. The only complaint about the chrysler slant six engine was the cracking of the exhaust manifold. If it has a diesel, you don"t have that worry.
Roger H
03-17-2007 19:32:23
 Re: case 960 combine ? in reply to jim handke, 03-16-2007 19:06:03
Jim, what's wrong with the ones with the 2 augers? Dad had the F345 on his 800 & he got along good with it, I have the combine now & am trying to get it going again someday.
jim handke
03-18-2007 12:26:59
 Re: case 960 combine ? in reply to Roger H, 03-17-2007 19:32:23
My uncle used the auger type and always complained about having trouble getting the corn up to the cylinder. It evidently was letting the corn run over the flighting. But he bought dad"s newer style when dad bought the 1165 and we went to shelling four rows. I probably overstepped my bounds when I condemned all the old styles out there. And I apologize for doing that.
