931 hydraulics
DJ930
03-16-2007 14:41:39
Would anyone have some ideas of why when cold my pump sounds like it is sucking air? When cold the hoses jump bad up and not as bad going down, but it moves slower when cold. I checked hyd. pressure and it is 1600 to 1450, book says should be 1700-1900. After it warms up, maybe 30 to 45 mins it will go away. I changed oil and filter after I bought it. It is a late 68 931 draft-O-matic 8 speed.Thanks in adavance any and all help. DJ
caseman-d
03-18-2007 10:35:59
 Re: 931 hydraulics in reply to DJ930 , 03-16-2007 14:41:39
Check for proper hydraulic oil. Possiblely to thick when cold and once its warm it pumpimg better. Most times it when it's warm the oil may foam and cause problems. caseman-d
