Changing Case 841C propane tractor to gasoline
bighood
03-16-2007 12:22:09
Wanting to swap to the Gasoline system from the propane system. Been told need a Carb and a Gas tank. I have a gas tank, but need info on a carb, and how to go about making the change.
Dedrick
03-17-2007 10:29:12
 Re: Case 841C propane tractor to gasoline in reply to bighood, 03-16-2007 12:22:09
I change a older 400 to gas A tank , gas line and an carburetor. I check case 830-840 and 830ck parts book and it look like this is all you need for a change over. John
INCase
03-16-2007 12:47:55
 Re: Changing Case 841C propane tractor to gasoline in reply to bighood, 03-16-2007 12:22:09
Not sure if you can bolt a gas carb onto an LP intake but you may want gas intake and exhaust manifolds to get the heat into the intake. Not saying it won"t work as it but.... something to think about.
